Rear Wheel
Rear Wheel
Hello everybody
I am building a 72 ironhead bobber with a weld on hardtail frame. I don't want to run the mechanical rear brake. What exact wheel should I be looking for? I know I need 18" but axle size is an issue as well. The hardtail has about a 7/8" hole cut. Thinking about trying to find something with a 1" axle and drilling the hardtail to match. All ideas and responses greatly appreciated!
Received 1,296 Likes
RE: Rear Wheel
Here's a couple links that might help:
http://www.sportster.org/tech/disc-conv/
http://www.saunalahti.fi/~affe2/v-tw...onversion.html
RE: Rear Wheel
If I remember correct sportster has 3/4" axle.... so if you are using sportster wheel you may need to make some spacers between frame and axle.
I have seen that Affe's bike and talked to him, brake setup is working just great and braking power is much better than original ( better than newer iron diskbrake)
-sepixlh-
-sepixlh-
RE: Rear Wheel
ORIGINAL: sepixlh
One thing to notice is to make sure that the master cylinder has a rigid enough position. System that I had wasn't very good, it had some flex when the brake was hit hard. Another way is to have a smaller volume master cylinder, HD master may be too big for that GSXR brake cylinder I used.
Oh, almost forgot... Nice to meet ya all
Affe
RE: Rear Wheel
ORIGINAL: prochopp
Hello everybody
Hello everybody
Just my 2c
Affe
