Confused cams
Confused cams
The moreI strip this '85 engine the more confused I get ! The PO said he had problems timing the cams . All cams are marked 1 through 4 Q so would seem right for the engine . BUT the crankshaft pinion is 3 teeth advanced and the front exhaust cam is 1 tooth advanced .The front ex cam has a dot ( correct for '85 I think ) as is the corresponding mark on the front inlet . The bike ran OK. Any ideas if these cams / pinion are right ( how do I tell ? ) or could some of it be from a later EVO or even another Harley ? Where should the crank pinion mark be in relation to the keyway ?
Also the manual gives a max and min end float for all cams up to '79 but just a minimum from then on . why?
