Ironhead A place to talk about Ironheads.
ironhead 77 or 79 custom build
Old 07-03-2011, 09:31 PM
demonito's Avatar
demonito
demonito is offline
Default ironhead 77 or 79 custom build
started out like this
clutch had a problem so we took it out and change the whole thing
stripped her bare
started to mock up her tail end
then we tripped her totally bare!
and we found out that the neck wasnt aligned! i think the previous owner had a fall or something
we make a make shift jig for her just to fix her up loose the weld on the top tube to the cast iron neck and hammered the down tube a bit and used a laser to check it was straight but not perfect though but tolerable
Old 07-03-2011, 09:34 PM
demonito's Avatar
demonito
demonito is offline
got her some parts
checked her with a triple tree on
did a mock up of the tank ad the tail end
Old 07-04-2011, 06:56 AM
scottfisher's Avatar
scottfisher
scottfisher is offline
welcome to the forum.
build pics are great!! keep them coming!
s
Old 07-05-2011, 07:41 AM
demonito's Avatar
demonito
demonito is offline
did a mock up today and rewelded some of the joint just to make sure before sending them to be powder coated
Old 07-05-2011, 07:42 AM
demonito's Avatar
demonito
demonito is offline
Old 07-17-2011, 09:01 AM
demonito's Avatar
demonito
demonito is offline
the frame and shocks are powder coated as well as the rims and hubs awaiting build up
Old 07-19-2011, 10:38 AM
demonito's Avatar
demonito
demonito is offline
demonito's Avatar
demonito
demonito is offline
sand blasting the engine well some parts of it
Old 07-21-2011, 07:50 AM
demonito's Avatar
demonito
demonito is offline
Old 07-21-2011, 02:57 PM
Chunk's Avatar
Chunk
Chunk is offline
That's not the "Porkster" tank, huh?
Quick Reply: ironhead 77 or 79 custom build
