Cv Conversion
Cv Conversion
Here is a pic of my cv carb set up. Have a questions re: the choke cable set up. I have seen what I think is the correct cable but I am not for sure. I dont understand how the cable gets connected to the carb. Can anyone shed some light on this? How did you mount the choke cable? I think my carb is a 1996.
Thanks
T-Ron
Thanks
T-Ron
I don't know anything about that carb, but I don't see where choke lever is. Looks to me like it is probably on the other side of the carb. I see what looks like a link from the throttle connecting to the accel pump but that's all I can tell from looking at that pic. And I could be totally wrong.
Yes you are correct, you are just missing that plastic nut, spring and plunger. Plunger might be in that hole but I can't see it.
In plunger there is place for cable or lever, when you pull plunger out enricher is engaged.
If you are missing that plunger carb will not operate correctly.
Collk88
Exhaust System Topics
11-15-2012 07:50 AM
WadsChopShop
06-17-2010 08:49 PM
accelerator, cable, carb, choke, concersion, conversion, cv, enricher, harley, install, installing, ironhead, plunger, sale, shovelhead
