Ironhead A place to talk about Ironheads.
New electrical problem
Old 09-05-2010, 07:30 AM
mustangwagz's Avatar
mustangwagz
mustangwagz is offline
Oil!? well..yah i'd say its possible that its messin with it? i dunno for absolute sure but possibly yes. i'm sure that with points, oil or water would deff mess with those.
How'd the oil get in your ignition cavity?
Old 09-05-2010, 07:46 AM
IronMick's Avatar
IronMick
IronMick is offline
Originally Posted by EvilWayz
i've got a electronic ignition, and i can confirm its working because timing led works. plugs are gapped at .35. well i guess i'm going to have to make me a friend and do the dark test. but there was oil i there when i opened up the cover would that confuse the electronic ignition?
There is an oil seal behind the ignition. If it leaks it should be replaced. I have not done that myself yet - my understanding is that you just pry out the old one with a pointed object and tap in the new one.
What i have heard: you have to be very careful to not wreck the soft aluminum mating surface; the seal gets completely wrecked as it comes out; oil the new one so it goes in more easily; be sure it goes in facing the correct way; tap it in using an appropriate size socket.
I do not know what would be the effect, if any, of oil on the ignition unit. It is possible for the unit to fail but the timing LED still work. But again, that may not be the problem.
I'll send you a PM with some additional info.
What brand is the ignition? Typical plug gap for electriconic ignition is 040. But this would not be the problem.
Old 09-06-2010, 07:43 PM
straydog13's Avatar
straydog13
straydog13 is offline
i have points and cant really comment on this....but i would be very curious to see if you have a light show going on with the cover off.
Old 09-07-2010, 05:40 PM
dirty78ironhead's Avatar
dirty78ironhead
dirty78ironhead is offline
I run points and don't know it this would be an issue for you but I lost both springs on the advance unit behind my points and had no spark..just a thought
T Ron
RKRider77
General Topics/Tech Tips
09-24-2017 11:38 AM
zaxcar
EVO
10-18-2009 03:44 PM
shovelpan
11-26-2008 06:37 PM
spammer89
07-31-2008 02:27 PM
UNCLE SAMMY
04-22-2007 02:00 AM
Quick Reply: New electrical problem
