Generator Noise?
So its been crappy weather lately, rainy off and on. perfect time to disect the generator. Tore it apart and to my surprise everything looked fine other than the brushes. a little wore, and outta spec. i replaced them bearings N such all sound and look fine. no excessive end play and absolutely NO lift or wobble in them. Ran bike without gen, still makes noise. after having a local ironhead owner/ mechanic listen to it, he simply smiled, shut the bike down and said "that my friend is the typical sportster cam gear slop your hearing." SO..guess that answers my question. haha he said its nothing to worry about. Cuz i havent seen anything in my oil so it apparently aint hurtin anything. just makin some noise.
i also re routed my speedo cable so thats a plus too. (Thanks mick on the cable removal process) Drag bars make it feel a WHOLE lot different to ride, and i like it alot more. more comfortable and easier to run the controls.
Next on the list of things i'd like to try, is the CV40 Slide carb swap. imma try and do some research on this whole process. Have any of yinz heard about ppl doin this swap? i was told by a few ppl it is a nice upgrade to a hassle free carb. (mine dont gimme problems, just seems a little to big for my application? i think it was originally used on the early 1200's? )
Anyhow, thanks to all that have helped! i appreciate it alot guys! Yinz deff know your ****!
You want to use no more than a 38mm.
The 40mm is made to use on a Big Twin which is a much larger engine.
pg
Oh, no doubt it did come off the Sportster. I am just saying a 40mm is too large.
Originally the Sportster came with a 38mm size and if I am not mistaken that was changed to a 36mm sometime in the 1980's.
I may be wrong about that because I am not up on the later model engines (after 1974), so don't quote me.
You can hang a 42mm carb on the bike if you want to, but it will not run right.
38mm is the perfect size.
pg
pg
The CV carb is considered a good upgrade for an IronHead. Have not done it [yet] myself. There are at least a few if not several or many write-ups on the process on the internet. A Google search should turn these up. You should find some sites with detailed instructions and step by step pics. Here's one ...
http://www.sportster.org/tech/
the 40mm cv i have came off of a 2001 1200 sporty, runs great on my "slightly" built 1000cc ironhead, didnt have to re-jet or anything, search ebay for a "branch" intake and a mikuni adaptor to connect the cv to the branch intake, i tried one of the cheapo adaptors that bolts to the stock intake, didnt work out real well,then you will have to make supports to hold the carb
