Ironhead A place to talk about Ironheads.
The Lollipop !
Old 08-18-2010, 08:08 PM
IronMick's Avatar
IronMick
IronMick is offline
Drill a 1/4" hole, a couple or a few inches in from the end, on the side next to the bike so that it does not show. Not too far in or you will have difficulty installing.
I used a washer that is about 3/4" OD - it just happened that in a huge box of spare junk there were two the same about that size.. The size does not matter, nor does the ID size. It just has to interfere with the flow.
A lot of guys use a thumb screw rather then welding a washer onto a bolt.
They are tuneable by slanting the washer. I kept mine straight up at 90` to the flow. Some guys prefer 45` angle.
Old 08-18-2010, 09:36 PM
98glider's Avatar
98glider
98glider is offline
is this better then using baffles( lolly pop) I have up sweep exhaust
Old 08-18-2010, 09:41 PM
straydog13's Avatar
straydog13
straydog13 is offline
hmmmm...i will try it....at least it will be on "the to do list".i always wished i was better in math to be able to actually do the calculations on intakes and exhaust.but if everyone can feel the difference its worth trying thats for sure.
Old 08-19-2010, 06:45 AM
IronMick's Avatar
IronMick
IronMick is offline
It is better than baffles if you like the sound that you have. Baffles will quiet the bike, lollipops will not. The lollipops are cheap and easy to try.
Old 08-19-2010, 05:40 PM
98glider's Avatar
98glider
98glider is offline
Does the lollypop just help with the back pressure I had open upsweep exhausts and then added baffles thanks
Old 08-19-2010, 07:51 PM
IronMick's Avatar
IronMick
IronMick is offline
Yes, and that gives you noticeably better low end torque/acceleration.
MaTcheS
03-03-2021 12:03 PM
apetterez
10-22-2014 10:28 PM
jim425
04-16-2010 04:35 PM
Bumbobee
01-16-2009 08:30 PM
fxsts1999
06-17-2007 07:10 AM
Quick Reply: The Lollipop !
