Exhaust pipe discoloration very different
I have spent the past winter doing a face lift on a 77 Sportster. I took it to a local wrench to adjust the timing and carb, hoping his "seasoned" ear would do better than my timing light was. Prior to taking the bike in, I checked the intake (but not the exhaust) for leaks and found none. Upon return, the bike runs well under throttle, but it idles poorly (uneven rhythm). Normal? I notice that the front exhaust pipe is getting much hotter (dark purple greyish patina) than the rear which is still honey gold in color. Is this indicative of a problem or standard for this engine? My other bike is a 97 Heritage and trouble free, this 77 has LOTS of personality (@#$&) and is a welcomed but new frontier for me.
Making sure the timing is set right(line in hole) is really important,NO intake leaks,same on exhaust..those items make them heat up faster than anything Ive seen.Is it a fresh top end? what carb are You using? On the idle,mine sorta lope..so far the best description Ive heard is the potato-potato sound as long as it stays around 900/1000 rpms steady I would thinks She is ok. Setting timing by "ear" is hit or miss at best.Mick and P.G. are the experts here..hopefully they will chime in.
A rich carb will discolor the pipes fast also.
IMO it is much better to do all of the tuneup stuff yourself. It is the only way to know for certain what is going on. And you really do need to know in detail. The problems you described could be caused by, or made worse by, and exhaust leak.
My tuneup sequence is ...
1. adjust pushrods with the engine stone cold. [1st thing in the morning works for me].
2. Check for intake and exhaust leaks
3. adjust pilot screw
4. if needed clean carb, adjust jets
Here are my notes [I added Setting Ignition timing on at the end] ...
Ironhead Push Rod Adjustment
Do this procedure with the engine stone cold. I usually do it first thing in the morning.
1. Remove the spark plugs. Remove A/C to make room to work.
2. Using a flat blade screwdriver pry the spring keeper off of each push rod; the bottom of the keeper pops out first, then the top. Alternately, use a 3/4" open end wrench to push down on the top of the spring retainer, then pry out the spring keeper with the screwdriver.
3. The lower push rod covers may be stuck tight against the bottom o-rings, but they can be loosened by pinching between thumb and finger [or carefully using a shop rag and a pliers] and twisting or rotating. Lift these up and secure each with a tall-S-shaped piece of 12 or 14 gauge household wire [not cable] [or a long piece of Plumbers solder such as 95/5 hooked over the rocker cover and under the push rod cover.
4. Jack up back end of the bike so that rear wheel is off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to 4th gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears.
5. To adjust a particular push rod, its valve must be fully closed [the valve spring is relaxed]. Valve position for a particular cylinder is determined by observing the corresponding push rod of the other cylinder. For example, when the rear cylinder intake valve tappet is raised [valve fully open, spring compressed], the front cylinder intake valve is fully closed, and the front intake push rod can be adjusted.
6. Check [and adjust if necessary] the push rods:
[a] use the rear wheel rotate the engine so that the rear cylinder exhaust push rod tappet is fully raised. The front cylinder push rod is adjusted correctly if it has no vertical or horizontal play, and you can just rotate the push rod between thumb and forefinger with no trace of binding or dragging.
[b] to adjust if needed: hold the adjusting screw in place with a wrench; with another wrench loosen the split locknut. Then turn the adjusting screw using fingers only until the pushrod's ball end is seated in the tappet with a "slight amount of play". Then tighten further as follows:
Option 1: Adjust on the tighter end of the range: There should be no vertical or horizontal play, and you should be just able to rotate the push rod between thumb and forefinger with no trace of binding or dragging.
Option 2: Adjust on the looser end of the range: Set the adjusting screw to finger tight so that you cannot turn the push rod between forefinger and thumb. Undo it a tiny bit so that it is just barely loose. Then loosen it 1 "side" for an exhaust or 1/2 "side" for an intake. "Side" refers to one side of the 6-sided adjusting nut.
EDIT: Experience here is that Option 2 is the better and most likely the correct choice.
[c] hold the adjusting screw in place with the one wrench; with the other wrench tighten the locknut.
[d] recheck the adjustment; it is common for the adjustment to go out as you do step [c], in which case [b] and [c] must be redone.
[e] repeat for the other push rods.
7. Use a flat blade screwdriver to push the upper push rod covers up, and seat them into the upper o-ring or cork washer.
8. Install the spring keepers, top end first, by prying them in under the bottom with a flat blade screwdriver.
Intake And Exhaust Leaks Tests
You cannot get a good tuneup if there are intake leaks or exhaust leaks.
1. Check for Intake Leaks
With the engine idling spray propane gas or WD-40 around the carb/intake/cylinder head joints. Propane is best because it leaves no mess, and is most easily sucked in thru leaks. WD-40 is said to work well because it has very fine spray droplets. Be careful to not allow any of either to get sucked in thru the A/C as this will invalidate the results.
Any change in engine RPM is a leak which must be fixed.
EDIT: Experience is that this procedure will identify larger intake leaks, but it may miss very small leaks that also must be fixed. And that propane is definetly the better choice.
2. Check for Exhaust Leaks
Pour about 1/2 ounce of oil into each cylinder thru the spark plug holes. Run the engine at idle. You will get lots of smoke for about 5 minutes.
All smoke should come from the ends of the exhaust pipes/mufflers. Any other is a leak which must be fixed.
Setting The Pilot Screw on Your IronHead
If the carb is old and dirty the pilot screw passage may be gummed up such that you will not be able to "gently seat" the pilot screw reliably. If this is the case remove the carb from the bike and clean it up. Some guys try to do carb work with the carb in the bike. IMO this is a very bad idea.
In the pilot screw passage there should be, in this sequence: screw, spring, washer, o-ring. [Often POs have installed these parts in the wrong sequence; remember that the purpose of the washer is to protect the o-ring from being damaged by the spring]. The screw usually comes out easily. The other parts may require some work. The best technique is to stick a pipe cleaner in the hole, twist it around, and, like magic, out come the other parts on the end of the pipe cleaner.
EDIT: The above info on the pilot screw applies to 1979 and newer carbs. For 77 and older there is nothing in the passage except the screw itself.
1. You need to have easy access to the pilot screw, easy enough to reliably judge "screw it in until gently seated". Loosen the front fuel tank mount bolt; remove the rear fuel tank mount bolt; prop the rear of the fuel tank up on a piece of 2X4; on some bikes this will not be necessary.
2. With the engine cold [so you do not burn your fingers] turn the pilot screw in clockwise until it is gently seated. Count the number of 1/4 turns as you do it; write the number down. Back it out to the original setting. You may need to return reliably to this setting after experimenting.
The "normal" starting point for this process is 1,1/4 [according to the 79 - 85 FM] or 1,1/2 [according to usual practice] turns out.
EDIT: An old HotXL magazine article recommends for Keihin butterfly carbs between 1/4 and 1,1/4 turns out. My experience is that this works best. If you are more than 1,1/4 turns out your pilot jet is too small.
3. The engine must be at full warm up. It will have very hot parts; to avoid burned fingers have a well lighted, comfy place to work.
4. Set the engine idling at about 1000 RPM. You want it to be idling at the slowest speed that is consistent with a smooth idle so that you can hear or feel slight changes.
5. Turn the pilot screw in clockwise until the engine idle becomes worse; tending to stall. Count the number of 1/4 turns as you do this. Then turn the pilot screw out counter clockwise until the engine idle gets good, then becomes worse, tending to stall. Count the number of 1/4 turns as you do this.
6. The best setting for your bike will be somewhere between these two settings. The FM says to use the leanest setting [most screwed in] consistent with a good idle quality. Some guys say to go between the two settings.
It should be between 1/2 and 1,1/2 turns out from gently seated. If it is not within this range you should change the slow jet.
EDIT: I follow the advice from the old HotXL mag article - set it between 1/2 and 1,1/4 turns out.
7. You may have to adjust the idle speed.
8. Make sure that the spark plugs are clean, then ride the bike around your neighborhood for 10 minutes. Keep it under about 15 MPH so that you are on the "idle port", not the "idle transfer ports", the "mid range port", or the "main jet" [see carb diagrams in FM]. Hopefully the plugs will come out a nice medium gray or tan color. If they are too dark you can screw it in another 1/4 turn; too light screw it out 1/4 turn, and try the ride again.
9. If they are really light or really dark the problem is not with the pilot screw setting. For example, too light might mean an intake or exhaust leak, and too dark might mean the pilot jet is too large [among other possibilities].
10. My experience with this process is that after making a change i have to clean the plugs and go for a good ride [say, a half hour or more] before i can trust that the new results are reliable.
Cleaning a Carb
1. Removing it from the bike should be straight forward. First thing when it is out is to check the pilot screw setting. Turn it all the way in until gently seated counting the number of 1/4 turns; then write this number down; then reset it.
2. I put mine in a vice to remove the screws, and for much of the following work. Wrap in a shop towel; close the vice gently taking extra care with the choke and throttle linkages. The vice is a needed extra pair of hands.
3. You must be very careful handling the float so as to not change the level. You must have the official specs for setting the level as in the FM, and check it, every time you dismantle the carb, as the last thing before putting it back together.
4. The jets are made of brass, a soft metal that is easily damaged. Use an exact correct size screwdriver. I ground a medium flat blade screwdriver down to exact size on my bench grinder to access the slow jet.
5. The general appearance of the inside of the carb is not necessarily a good indication of its condition. It can look spotless and have clogged jets, or look cruddy and have clear jets.
6. Ignore any advice that says to soak or boil the whole carb in carb cleaner. Rather, clean each individual part. Do not allow any solvents to contact any rubber parts [tip of needle, o-ring seal for bowl]
7. Make a list of all of the jets and passages for your carb using the carb manual or the FM for the bike. Then ensure that you can blow either compressed air or carb cleaner thru each one.
8. Remove the pilot screw and clean the parts and the passage. The passage contains in this sequence: pilot screw, spring, washer, o-ring. These are very small parts, especially the washer and o-ring. Usually the spring will easily fall out. One time i thought the spring was not in there because it would not fall out; i obtained a new spring and could not get it in! The technique for removing the washer and o-ring is to use a pipe cleaner: stick it in the hole, twist it around, remove it - you should see the washer and o-ring on the end of the pipe cleaner.
EDIT: the washer and o-ring are part of the pilot screw assembly for 1979 on. They are not in the 1978 and earlier Keihin carbs.
Remember that the purpose of the washer is to protect the o-ring from the spring and you will always get them back in in the correct sequence.
9. Dismantle the accelerator pump assembly noting carefully the sequence and orientation of the parts. Clean and inspect the parts. Replace the diaphragm if it is cracked.
10. Check the float level then carefully put it back together. I personally find it very confusing trying to decide which way to bend the tang if it is not correct. If the fuel level is low is the float high or low? Do i need to bend the tang up or down? On the bench the carb is usually upside down, adding to the confusion. Sort all this out before making an adjustment.
Best to replace the original Phillips screws for the bowl with stainless steel socket head screws.
Setting The Ignition Timing on Your IronHead
1. Checking vs Setting the Ignition Timing
You can check the timing without changing anything. Changing the timing can be done by one person but is easier with two. The ignition module or points is on the right side of the bike, the timing hole is on the left side. Easier with one person on each side than to go back and forth. Standard advance for the 1980 XL is 40`. I have mine set at about 35`. At 38` i get pinging.
2. Equipment That You Need
You need an induction timing light which you can buy at any auto supply store. Best to get the "dial back" type. These allow you to set a number [like 35`] into the timing light and then adjust the ignition module/points backplate until you are there.
If you have very well insulated spark plug wires the timing light may not sense the signal thru the wire. If this is the case then open the gap on the spark plug to 050 or more. Reset it to your normal gap [030 for points or 040 for electronic] when done with this procedure.
It also helps to have a throttle lock as the timing should be checked/set with the engine at 2500 to 3000 RPM.
You will need a piece of rubber oil line hose about 1 inch long. Press one end up against the side of a stone grinding wheel [or whatever] to make sure it is perfectly flat.
3. Front Cylinder: TDC Mark vs Advance Timing Mark
The TDC [Top Dead Center] mark is used with a dial back timing light to check the timing, or to set the timing at a specific degree, such as 37`. The advance timing mark is used to set the timing to the factory setting, such as 40`. Best is to use a dial back timing light to check or set timing.
4. To Identify Your Front Cylinder TDC Timing Mark
Remove spark plugs. Rear wheel off the ground, shift to 2nd gear, rotate wheel until it clicks, repeat until you get to top gear. Now by rotating the rear wheel you are rotating the engine. Almost impossible with the plugs in; very difficult in lower gears.
You want the front cyl to be at TDC. You can see in thru the spark plug hole, especially with a flash light; you can try inserting something soft like a pencil and watch it rise and fall as you rotate the engine with the back wheel but be careful it does not break or get stuck! You will have to hang on to the pencil with left hand while rotating the rear wheel with the right. Helps to have a good wingspan, or an extra person.
With the piston at precisely TDC look in thru the timing hole. You should see a drilled dot or a line. That is your front cylinder TDC mark. Once you know for certain what the TDC mark looks like you can check the timing.
5. Procedure, Checking The Timing
Begin with the engine at operating temperature. Remove the timing plug from the left side of the engine. Insert the 1" hose smooth end first, right tight up against the flywheel. I use a needle nose plier and twist it in there as firmly as i can. If it is not smooth and tight against the flywheel oil will spray out while you are working.
Start the engine, have it at about 2500 to 3000 RPM [it will be extra noisy with the timing plug out], set the timing light at 40`, aim it into the timing hole thru the hose. Click it down one degree at a time while you look for the timing mark. If you don't find it you may have to work up from 40`.
If it is in the 35` to 40` range and there is no pinging then you may wish to leave it as is. With pinging on acceleration you may want to retard it by about 1/16 of an inch or less [see Math below].
6. Procedure, Setting the Timing
Remove the points cover from the right side. You will be rotating the back plate so first mark it so you can get back to the current position if needed. Make a scratch mark or use a permanent magic marker, or better still a small bright red or whatever color paint mark.
To change the timing loosen the two standoffs holding the points/ignition module and rotate the backplate. Clockwise advances [larger degree number] counter-clockwise retards [smaller degree number].
7. Some Math, How Much to Rotate
The backplate has a 3" diameter = 1.5" radius.
The circumference = 2 * pi * radius = 2 * 3.14 * 1.5 inches = 9.42 inches
The circumference = 9.42 * 16 ~= 151 sixteenths of an inch.
One rotation of the backplate corresponds to two rotations of the engine, so it is like a circle that has 2 * 360 = 720 degrees. 720 / 151 ~= 5
Therefore a rotation of the backplate by about 1/16 of an inch results in a timing change of almost 5 degrees!
Cleaning a Carb
I'm not sure if my last posted, but thanks to everyone for your time and knowledge. Mick, the smallest propane source I am familiar with is the one attached to my grill. What do you use for this application; how is it dispensed? Would this test and the exhaust leak test tell me the same thing as the fore mentioned bleed down test?
I use a propane cylinder typically used for soldering plumbing etc. Available at any hardware store, building materials store, Home Depot, etc. Or use the one intended for camp stoves [but it does not come with a convenient nozzle].
The workshop version usually comes in a box with a nozzle included; sometimes a flint lighter is included also - but of course you do not need this, eh.
Screw on the nozzle. Then with the engine at idle turn on the little tap, aim the nozzle at the joints between the manifold and the head, and the manifold and the the carb. Hold it in each position for some time. If any of the propane is sucked in thru a leaky spot the engine RPM will change [probably go down].
There is no danger of the propane lighting or exploding or anything like that.
The leak down test is entirely different. It checks the internal engine components to see if the valves or rings are not sealing - which would indicate a worn out engine needing a top end rebuild. If you suspect that a rebuild is needed the leak down test can be useful to get an idea of what to expect.
I think the testers are about $50 to $75. Many guys make their own. Plans can probably be found using Google search.
1980, bent, clean, discolor, discoloration, discolored, engine, exhaust, harley, pipe, pipes, push, rod, shovelhead, trouble
