Wide Glide frontend
Wide Glide frontend
OK i want to add a wide glide on my 78 hardtail. I understand the neck cups will need to be changed. I have a few other questions.
I was thinking about getting some with a rake built in not sure how much.
What length tubes ? I want the bike to set level with a 21 inch front wheel.
Since I am switching the neck cups what year trees would fit?
Is it posssible to use the same tubes I have on it now with the narrow frontend and would the stock length be ok with some rake like 3 to 5 degrees?
Thanks in advance for any help.
T-Ron
T-Ron
cant help you with the length, but yes they do make trees to use your tubes to make a wide front end, as far as rake goes the raked trees are TOTALY unsafe it throws the handling out the window, the rake and trail have to work together to make a safe ride, if you rake the trees it throws the trail way off making a bike that is no fun ( and not safe) to ride! r and b racing has a real good rake and trail calculator on their sight that you put in all your info as far as tube lenght, wheel size etc. go do some reading before you waste money on raked trees!
the frames that are raked do keep the correct trail, no problem at all, when you just add raked trees is when you have problems, i thought about raking my frame, i just could not bring myself to cut a good frame! how about getting a aftermarket frame, then when you get tired of it you can switch back to the original frame, after all every time some one cuts one thats one less original left!
