going digital
Not sure if this helps / hurts any, but a buddy of mine runs a 72, and his old speedometer cable USED to run through a hole in the bottom of the case, which I am told a lot of folks plug / weld shut to avoid oil leakage.
This is at least a prospective safe point of entry, maybe? Beyond that, I'm not on familiar ground running sensors into motors, etc., nor do I know what parts it entails - so the rest is up to you!
Anyone else?
- Al
EDIT:
As a side thought, after reading GA's post - in my '83 I pull a signal for the tach electronically from the coil. Is this something you can do as an alternative? Or, maybe something you can do in the points cover area rather than go directly into the case?
Else, I imagine there's some kind of drivegear you'd have to go off of for the RPM's. Wheel hub seems like most accurate / best way to get a speedo reading, too - I'll double down on that idea.
Anyone else?
- Al
EDIT:
Seems like pulling a signal off the ignition would be a lot easier way to deal with the tach. I'm not sure how they would correlate transmission speed to engine RPM, anyway.
I'm not sure how the later wheel speedos work, but I'd explore getting the signal from the front wheel hub for the speedo.
Got a link to those units?
http://www.wire-plus.com/Rectangle-S...eter_p_13.html This si the pne i want, but the dakota one is pretty sweet too:
http://www.dakotadigital.com/index.c...rod/prd622.htm
Seems to me like the first link, at least, is going to require an EI - and that they really DON'T want you to hook the tach directly up to the coil. Also, there presently isn't a transmission sensor in your bike I imagine.
I guess if you really wanted this nifty gadget, you would want to look into converting to EI and finding a way to install a transmission sensor first. That's what I'm gathering from the tech. manual (which really didn't help too much on the wiring schematics side of things).
- Al
- Al
There is absolutely no way this can be used on any IronHead. There is no sensor in the transmission, and one cannot be installed.
