Mazda starter?
Well, it is kinda true.
I can tell you this...........
Various small jap cars use the same "starter motor" as late sportster, as in sportster that use the one piece starter set-up, from around 81 up
But it is only the actual starter motor that is the same
the drive housing is different
As in, the side that faces the starter motor is the same, the side that faces the engine is different
so you just get to use the motor part, fitted into the original harley housing
I think toyota corona(some years) is a contender
