Rocker Box Leak
Rocker Box Leak
I have a leak on the rear rocker box on the right side of the box(not the side with the red nuts). Since its going to be getting cold here in Chi-Town I figured its time to fix it. I would like to re-use the rockers and the shafts. Any tips or suggestions ? The motor will be out of the frame, for paint.
Thanks in advance for any help.
T-Ron
T-Ron
To remove the screw........ Use a hand held impact driver and a large hammer. You will never get the screw out using a large screw driver, so use the impact from the git-go.
pg
Ok thanks I have the allen head type. Its the o ring that's sits in the groove in the rocker box? Do you have a size you could provide? So maybe I can fix this problem without taking the rocker box any further apart? That would be cool! I always hate to take it apart when its running so good!
Thanks
T-Ron
Thanks
T-Ron
Thanks
T-Ron
Thanks
T-Ron
The allen head needed is a 5/16 inch. Use the impact tool to remove the screw. You remove the screw without having to take anything else apart.
pg
If it was to me regarding removing the screw, then the answer is no.
It makes no difference if the valve is open or closed when removing the screw(s).
pg
