my ss braided rocker cover to crankcase oil lines came in today. when i take the old line off will there be oil coming out untill i get the new one on? should i put thread tape or never sieze on theme before installing? thanks in advance guys
not much oil will come out, i used a little liquid thread sealer on mine, make sure you put the correct end down ,you will see that one end has a "taper" on the inside of the line, this is the end that the oil goes into, this end goes on the bottom
