What's Considered Normal?
I was out riding my 1980 XLH and I notice that the bike is perfectly smooth up to 50mph. As I get to 55 I start to pick up vibrations in the seat and an overall rougher ride. I have no vibrations in the Handlebars and any speed. Now the RPMs at 55 are just about 3000 I think. Is this the normal sportster shake. I believe the vibrations have more to do with the RPM's then the actual speed. So I think I can rule out tire balance. The shaking is not excessive just rougher feeling. Thanks for your help!!!
Sounds about like my '83. I put a 23 tooth transmission sprocket on it to lower highway rpm's. It hurts the acceleration a little, but 3000 rpm's get me to a little over 60 mph with that gearing, which is pretty smooth. It's actually not too bad at 70 mph, either, which is about 3400 rpm now.
I too use the 23T front sprocket, 51T rear sprocket on my 1980. It is an ideal combination. "All the ironhead guys" around here use it.
Probably not a problem. But you should check out the usual things as already suggested anyway, especially if this is a new developement.
Wheel bearings, ignition timing, chains too loose or too tight, broken/loose engine mounts, tire pressure, loose spokes, fork oil [try 15W], set rear shocks up one level tighter, not sure what else.
