67 xlch rocker arms
67 xlch rocker arms
can anyone tell me if the stock rocker arms will work with an s&s hot set up, whoever built my motor installed hydraulic rocker arms in the stock rocker boxes and they are rubbing against the upper valve spring collars. the s&s rocker kit is fairly expensive i just want to know if stock parts will work before i drop the cash. thanks.
