Ironhead A place to talk about Ironheads.
cv carb brace
Old 05-03-2009 | 12:30 PM
shepdog's Avatar
shepdog
got the slow jet out it is a 42,170 on the main, i only have the mixture screw out about 3/4 of a turn now but it runs good starts right up runs smooth down the road, does not seem to be spraying gas anymore!, must have had it way rich on the idle mixture adjustment, yes i read ga ironheads info there is a lot of good info there! thank you for the help!
Old 05-07-2009 | 07:15 PM
shepdog's Avatar
shepdog
well i got ot on and it starts up and runs good, BUT how much more performance should i expect out of the cv? it starts up and runs but the stock 25+ year old keihn runs circles around the cv,it lacks bottom end mid and top end,the cv falls flat around 70mph the stock carb pulled hard way past 100 mph! i do have to run the slow adj. only about 3/4 of a turn out, any ideas what to try?
Old 05-07-2009 | 07:52 PM
IronMick's Avatar
IronMick
I put cv carb tuning in the google search. Here are two good links ...
http://www.harley-performance.com/ha...arburetor.html
http://www.nightrider.com/biketech/hd_cv_mods.htm
Old 05-08-2009 | 01:29 AM
sepixlh's Avatar
sepixlh
As Mick wrote that nightrider instruction about modifying CV is good source.
Drill that ventilation hole to 1/4" and put 48 intermediajet, maybe 180 main jet
add that spacer under needle..as instructed there...
SE offers dynojet thunderslide kit OEM#29936-98A
"The unique composite slide, emulsion
tube and slide needle make the CV carburetor come
alive when used with free flow intake and exhaust" Costs more than used carb...
sandyreilly
07-19-2011 09:39 AM
patharley
EVO
07-13-2011 08:10 PM
jhowle9475
Exhaust System Topics
08-30-2010 05:37 AM
terrapin88
04-06-2010 11:17 AM
bryon857
Ironhead
02-21-2008 06:56 PM
Quick Reply: cv carb brace
