Ironhead A place to talk about Ironheads.
Just venting (pun intended)
Old 03-04-2009 | 07:01 AM
IronMick's Avatar
IronMick
This site: http://71.42.59.226/hotxl.html has all the HotXL tech articles posted. He has had them posted for a long time, in Adobe Reader format. You may need 7Zip to unzip them [WinZip would not work for me, but i may have made an error with it]. It would be worthwhile for someone to ask him about copyright. He is very good at answering questions if you e-mail him.
Old 03-04-2009 | 08:21 AM
Calwoodbutcher's Avatar
Calwoodbutcher
Pinion, Ah, the gear shifter cam plate. That makes sense. The trans shifts and holds on the bench but that aint the "real thing" if you know what I mean. I didn't take the whole trans in to have it checked, only the gears and forks in a box. You might have hit the nail on the head (once again) . It will be a while before I get to this. I will let ya know what shakes out. Thanks again to all you guys.
Old 03-04-2009 | 08:43 AM
piniongear's Avatar
piniongear
OK, a good look at the cam plate is in order. If the 2nd gear notch looks different than the other notches, it may be worth changing out the plate.
I do not think that will be cheap but it could solve the problem.
Good luck with it and we will await your findings........... pg
Old 03-05-2009 | 12:54 AM
sepixlh's Avatar
sepixlh
There is option, if there isn't excessive wear to modify cam plate...
Most of these modifications apply also to Ironhead XR-1000 racing they are all useful specially tuned bike.
13RoadKing
The General Motorcycle Forum
36
04-01-2017 04:09 PM
jneva
07-16-2015 12:04 AM
bdtaylor1979
07-19-2014 11:29 PM
stro1965
01-25-2008 06:21 PM
Quick Reply: Just venting (pun intended)
