83 ironhead
83 ironhead
Hello everyone. I am new to this forum and I need your help. I bought this 83 sportster last year. I rode it through the summer and now I have tore it down to the frame to rebuild and put my mark on it. This is my first bike restore project and I'm quite anxious to see it go back together but I would like to do it right. My first challenge is the trany. It has always been hard to shift and likes to stick in 4th and 3rd gear. I let my son in law ride it one day and he brought it back broke. He said it stuck in 4th gear and he must of kicked the heck out of it because he knocked the shift arm out of the prawl. I have removed the trany and everything looks ok but I know its not. Any advise on this. Also when I removed the back tire I noticed that the rear axle does'nt fit any more like the swing arm spread open what is going on with that.
First of all get rid of the son-in-law ! That trans has to have a set of experienced eyes on it you did the grunt work get a good sporty mechanic to look at it could be anything from the paul carrier to shift forks to cam plate and so on as far as the rear axil swing arm are you saying there is too much side play on the rear wheel (side to side ) ? also make sure the rear swingarm doesn't have alot of play (swingarm bearings )
Sounds like you do not have a manual yet. You need these:
factory manual
parts book
Haynes
Clymer
The first two are absolutely essential for any ironhead owner. The last two are very helpful with some better pictures and alternate explanations.
Then you are in a much better position to discuss details with the forum people, any shop you might go to, etc.
Sorry, not a tranny expert myself, so this is all i can offer.
factory manual
parts book
Haynes
Clymer
disc brakes
The restore is coming along pretty good. Thanks for all the help. My problem today is the disc brake rotors. The bolts holding them on to the wheels will not budge. I twisted a new allen head socket and did not even move the bolt. I think they are lock-tited in there. Any advise on how I can remove these bolts.
