rear mount
rear mount
i just had my motor out of my late 84 xl to put gaskets and seals in it checked verything looked ok, but after i put it all back together and was putting my chain on i found that the rear mount is cracked where the top bolts go down thru the block, can i get that mount out without pulling the motor again?or should i leave it alone?
If you get lucky you will be able to 'unscrew' the studs out of the left side crankcase half, remove the engine mount and then install a new mount and thread the studs back into the case. The engine still has to come out though.
It will take a good bit of luck to be able to do this however because at least one of the studs are usually really tight.
Here is my recommendation:
Since the mount is broken, it is no doubt made of aluminum. My '71 had an aluminum rear mount and it cracked also. I was able to find an older mount made of steel (steel mounts are becoming a very rare thing these days) and installed that on mine.
If all I could have found was an aluminum mount, then I would not have bothered changing it out. Most of the aluminum mounts crack sooner or later (sooner mostly) and another replacement is going to do the same.
I suggest you not be concerned with the cracked mount. It is there to hold the rear of the engine and has top bolts going into the block and side studs holding things tight left to right. In other words.....the engine is not going anywhere. Just keep running it with the cracks and I believe it will be fine. If you happen to come across an old steel mount though, grab it up if you can get it for $50 to $75 and then consider replacing the cracked mount.........pg
