78 xlh carb....mikuni vm38????
Guys often measure these incorrectly. Just to be clear, it is measured at the narrowest part of the venturi. Might be easiest to measure from the back end. What i do it cut out a piece of cardboard or stiff paper the size i think the carb is and stick it in there.
Received 1,296 Likes
If it's a round slide Mikuni, it's probably 38 mm. They were a pretty popular aftermarket carb for HDs back, especially in the mid-late '70s. No longer made, and hard to find parts for now. Unless you just gotta have it, it'd probably be better to swap it out for a newer carb.
38, 78, aftermarket, carburetor, harley, ironhead, measure, mikuni, mikunu, mm, panhead, shovelhead, slide, sportster, vm, vm38, vm38specifacitions
