Newbie needs help
Newbie needs help
I just bought a 1976 Sportster about a week ago, and just put a battery on it so i could start riding it. I fired it up tonight and let it warm up for a minute. After it warmed up some i turned the choke off and started to ease on the throttle and it boggs down everytime i do it. Also when i put it into gear it will die and wont resart until i get it into neutral. One final major problem i think is when i shut it off after getting it into the shed i could hold onto the rear pipe and nopt get burnt, but i touch the front pipe and it burns the crapout of my hand. What could be causing these problems and how do i fix them.
By the way I have no experience with a harley other than this one and riding my buddies bike.
RE: Newbie needs help
Cool, so again it sounds like you do not have any fire in the rear cylinder, which could be as simple as a bad spark plug. You might just swap plugs and see which cylinder then fires. If the rear still does not, then it could be plug wire, coil or more. Let me know and feel free to PM me.
Sportsterd
13
04-19-2008 01:27 PM
