Question about clutch adjustment on 68 xlch
There is a little return spring to pull it against the stop. Now adjust the clutch cable length by backing out the handlebar cable adjuster just until the releasing lever behind the kicker cover comes off it's stop. Was wondering is there any way of telling it hit the stop without taking off the \\; kicker cover ?? Any help would be great thanks guys
 \\;Roger
 \\;Roger
RE: Question about clutch adjustment on 68 xlch
I am not sure what you are trying to do here, but I will assume you want to adjust the clutch cable? if that is the case, then this is what you need to do:
I will not (waste time describing how to do it), just read the text and refer to the diagram.
Do not get into the clutch adjustment with the 6 springs inside the primary. You do not need that, just the cable adjustment..........pg
[IMG]local://upfiles/8331/7D09292776AC4637BC2E434F53A15483.jpg[/IMG]
[IMG]local://upfiles/8331/7E47D8F558B247A8BC6D0DC8F05A3658.jpg[/IMG]
Ok PG what I was talking about is the worm gear that has the spring in it in the kicker cover is ther anyway to tell when it is at its stop just buy the lever or do I have to take that off again Oh by the way bike fired up and ran nice today with the new mikuni onthere the 38mm I emailed you about the other day thanks bud Roger
Hi Rolson,
Proper way, as per manual...
- Slaken cable at lever end
- Untighten worm nut
- Screw IN the worm adj. screw so the rods push on the release plate and this will force the worm back onto its pin stop
- adjust play at lever end, about 1/8th
- Unscrew adj. screw until you have the same amount of play
- Tighten nut,
Eh Presto, job done...
Patrick
PS, I see this forum is still screwed up on the typing front!!!
- Tighten nut,
Patrick
Really screwed up Patrick! I have to type fast and short or else the massage will not post.
Error message says 'Connection timed out.'.........pg
PS: I have given up all hope that this will ever be fixed, or the backslash business being fixed either.
