starter relay?
starter relay?
the starter relay on my 75 sporty gets power at the small terminal when i push the starter button in but sometimes nothing happens at the seleniod or the starter.if i cross the two large terminals on the relay the engine will kick over.i guess my relay is bad,am i right?can it be taken apart and cleaned?i tested it with it off the bike and it clicked like it should.anybody got any suggestions?
RE: starter relay?
If it is the round relay, its not repairable. \\; You can take it to an autoparts store and they can match it up with an automotive type. \\; About 13 dollars. \\; Relays are high wear parts and they do go bad. \\; \\; The small terminal is the trigger when activated it makes a connection between the two large terminals. \\; Just like the solinoid the connector plate gets pitted after awhile. \\;
