oil line routing
RE: oil line routing
Your oil tank has a bottom connection that is the feed line to the oil pump.
The oil return line connection and the vent connection on the oil tank may be on the bottom of the tank as well, but these two connections will have an internal standpipe on each if they do go into the bottom. This depends on what type of oil tank you have. Either connection can serve as the vent or return, but the larger connection (if different size) is used for the return line. The return should also be the farthest from the feed connection.........pg
