Wiring Question, Dont want to set it on fire!!!
I am going to install the starter relay on my 78. The one I have is marked suppressed diode on the bottom and mounts under the batt. tray on the left side. It does have a "s" marked on top by one of the larger post.
This is how I am going to wire it:
batt+ to relay
relay to starter soleniod
soleniod to starter
using 2 gauge cable
Also after reading some other post I should also have the wire that goes from voltage regulator to batt+ and starter button to starter soleniod going thru this relay as well is that correct?
Thanks for any help
.T-Ron
batt+ to relay
soleniod to starter
using 2 gauge cable
Thanks for any help
.T-Ron
RE: Wiring Question, Dont want to set it on fire!!!
Positive battery cable to solenoid
Same post as above run a 16-18 guage wire from solenoid to relay
Regulator to Relay
Starter Switch to Relay
Green 16-18 guage wire from relay to solenoid.
Starter button to relay
https://www.hdforums.com/m_3454351/tm.htm
Regulator to Relay
Hey Randy,
Thanks for the reply but I think I had to many beers, I \\; am even more confused any chance of a sketch? I have been looking at your other post w/ pics but I am just not getting it. Any clue on the post marked "s" and one marked "i" ?
Thanks again
T-Ron
Thanks again
T-Ron
I didnt mean to confuse you. \\; Its hard to type with teh forum issues. \\; Heres two pictures for you. \\; I hope this helps
[IMG]local://upfiles/49728/27BFA90B34404738B5D579B19A9FD488.jpg[/IMG]
[IMG]local://upfiles/49728/1BF234022D2A41518D9F712A37D3F39B.jpg[/IMG]
Randy,
What ever you posted and attached isnt there, so if you please try again that would be great. I am trying to get the wiring buttoned up by the weekend its supposed to be nice here in chicagoland.
Thanks again
T-Ron
Thanks again
T-Ron
