Starter blues......again
Hey everybody....I know I posted a concern regarding which starter to use on a 76 Ironhead, ut after contacting all the resourses I can think of and using the forum up till this point I have yet to find out the right answer. It turns out the Hitachi style starter has two through-bolts that not only don't line up perfectly with the holes in the starter housing, but also are no where near long enough to go through the housing itself with any substantial length. I guess my question is....is the Prestolite the right one after all? I bought this as a basket and am trying to peice together something with no references other than a useless Harley manual. Thanks, Tid Bit
RE: Starter blues......again
I replied to you in the newmebers forum but I'll add to that:
As far as the thru-bolts not lining up correctly, I really can't answer.
As for the bolts being too short. Make sure the starter is pushed all the way into the housing on the motor. Mine took a little bit of pressure to get it in tight.
Received 3,346 Likes
