Ironhead starter issues....
Hello,
I am the actual guy that is having trouble with finding the correct starter for my 76 Ironhead....I know it isn't rocket science, but I am new to the Sporty line (have always dealt with big twins). Anyhow, the real question I have is - was there a difference in starters from a solid electric start motor as opposed to the kicker/electric combo? I purchased a Hitachi style starter from Ebay that was specifically listed for the 76 model, but in no way do the through-bolts line up (off by a fraction to the actual housing) and the molded shroud around the starter gear will not fit through the hole in the starter housing (diameter on the housing is too small). Please help if you can....about ready to ditch this whole project because for some reason, it has turned into rocket science!
RE: Ironhead starter issues....
Well my 77 xlh uses a prestolite starter motor, my buddys 76 also use the same one....now they were both non kick start models.....I thought that the only difference was the outer cover??? I have been wrong before....I also thought the Hitachi starter fits a little later model sporty???? Again i think, and have been wrong before.......JERRY
I have a 74 ironhead electric start only and it uses a hitachi starter. I think there are only the2 starters prestolite and hitachi. I put a new chrome hitachi starter on last year and had to grind the chrome of the end to get it to fit . It would'nt fit due to the thickness of the chrome. The prestolite starters are longer and thinner. You should be able to get info from a Jireh cycles or Jp cycles catalog.
