Ironhead A place to talk about Ironheads.
DEAD BATTERY!
Old 05-12-2008, 08:23 PM
sutphen30's Avatar
sutphen30
sutphen30 is offline
Default RE: DEAD BATTERY!
What Gauge wireing should I be using?? When you splice the wiring are you using but crimps and then heat shrinking the connection??
Old 05-12-2008, 08:25 PM
sutphen30's Avatar
sutphen30
Thats an Idea!! I will have to give that a shot after I re-charge !! Wonder if any one has a diagram of the way the regulator is supposed to be wired??
Old 05-12-2008, 08:27 PM
sutphen30's Avatar
sutphen30
With the solid state you just splice the lines / not terminals?? Do the mounting holes line up??
Old 05-13-2008, 08:24 AM
Calwoodbutcher's Avatar
Calwoodbutcher
Calwoodbutcher is offline
Mine had an in lineharness connector (4 or 5wire plug I think). Some of the wires had to be spliced on the bike side of the connector. I used straight in line connectors with heat shrink over them. All of the mounting holes on the regulator did not line up so I lined up the bottom ones and drilled a mounting hole for the top one. Used a self tapping screw there. The wire guage can be determined by the amp draw of the curcuit you are doing if you want to run new wire.
All Aces
12-20-2011 05:55 PM
Greasemonkey1
07-28-2010 10:38 PM
ss377
02-01-2008 08:05 PM
murph
12-12-2007 10:02 AM
seven7
08-31-2007 06:14 PM
Quick Reply: DEAD BATTERY!
