intake seals? carb recommendations
I posted about the problem with sputtering in 4th gear, well I went out today and its doing it in all gears from about 1/3-full throttle. I pulled the carb and the intake manifold to check the rubber o-rings. Are these rings suposed to have silicone all around them? anyways didnt seem to have any air leaks. I think the problem is the main jet in the carb (too small) , which is an edelbrock quicksilver, I hate it. I cant find replacement needles for this carb anywhere. I want to go back to an old fashoned simple carb. anyone have any recomendations for a carb. 75xlch .20 over, drag pipes, 10:1 ,
RE: intake seals? carb recommendations
Most people are going to recommend S&S Super E, but those things cost a butt load of money! Try a Mikuni 38MM VM round slide carb. You can get them for about 100 on ebay. Parts are hard to find for them but I found a site that sells jets, and rebuild kits for them.
An S&S Super E.Yes they are expensive but imo worth it.I put one on my 75 xlh 3 years ago,adjusted it per s&s.com instructions and it has purred ever since without adjustment of any kind.I would in no way shape form or fashion buy a used carb from anywhere.They are for sale for a reason..Kinda like going to the junk yard and buying a used carb for a vintage cuda.You get what you pay for.
ORIGINAL: pitbull1
Really people are going to give you different answers. Each carb has its upsides and downsides. I sort of prefer the mikuni, but I have heard some really good things about the S&S. Even the stock Keihin's were a good stock carb. Much better in my opinion than the bendix's. But thats just my $.02
