Chain lubrication
RE: Chain lubrication
I use Castrol "Chain Wax". Lube the chain with this stuff at least an hour or two before you ride (the night before works best), and it stays on pretty well. I've also had good luck with PJ1 Blue (but it's sticky if you get it on anything else). Don't use PJ1 Black or HD chain lube. Those will sling off more lube than stays on the chain.
Buy a nickel plated chain and kiss heavy lubes goodbye. Nickel is self lubing. All you gotta do to maintain the chain is wipe it down with WD-40 or similar every now and then to clean it and lube the pins.
I have been running nickel plated chains for 10+ years and have had good results. I was using Tsubaki chains, but they are expensive. About 110 bucks each. Last year, I picked up this Western Powersports nickel plated chain for about 30 bucks. I have no complaints with it.
[IMG]local://upfiles/17633/C6E3D08EB22846E696E991C0A8614FF1.jpg[/IMG]
[IMG]local://upfiles/17633/6F7A732337724CEC8FCABB6FCEE2D594.jpg[/IMG]
RK is a brand of chain. You can cross reference the number here to find out what chain you have:
http://www.ftmbiz.com/street_rk_chain.html
