Backfire on start-up
1 Post
What would cause an engine to start backfireing on start-up all of the sudden. It has been doing it for a few days now. The plugs are not fouled, but the front cylinder does not seem to be fireing initially. After a few attempts to start which results in backfireing, then fireing on the rear cylinder, and then both very roughly until it warms up and then runs fine.
RE: Backfire on start-up
Did you ever get the problem fixed? If the pushrods are out of adjustment on your front cylinder then it could be holding the coresponding valve open and allowing too much air in. After it runs for a bit, check the spark plug on the front cylinder and make sure it's not too rich or too lean. The Ironheads vibrate like crazy and it's not uncommon for the pushrods to need a little adjusting every now and then. I saw a thread somewhere around here that describes how to adjust the pushrods so I won't re-post it. Good luck!
Here's the link to the post that I mentioned earlier. Having your manual handy helps too if you have one. This post explains Ironheads, Evos, S&S, etc. It's pretty thorough. If you have any questions, just let me know.
https://www.hdforums.com/m_95088/mpa...s/tm.htm#95088
