Ironhead A place to talk about Ironheads.
Stripped lifter bolt 77 XLH
Old 12-06-2007 | 09:34 AM
83XLX's Avatar
83XLX
Default RE: Stripped lifter bolt 77 XLH
Technically speaking, the pushrods aren't adjustable. The threaded adjuster is on the lifter.
Old 12-06-2007 | 09:47 AM
ScooterHD69's Avatar
ScooterHD69
ORIGINAL: 83XLX
I believe you are correct, I had forgotten about that. It's been a long time since I adjusted the lash on a Sporty.
Scooter
Old 12-06-2007 | 11:41 AM
ragrat64's Avatar
ragrat64
So I am assuming that I can take the pushrod & tube out without removing the head so I have more room, GREAT!!!!
Old 12-06-2007 | 11:59 AM
83XLX's Avatar
83XLX
Yep, just turn the motor over 'till both valves are closed (take the spark plug out and watch for the piston reaching TDC - every other one will be the compression stroke). Pop the pushrod cover keepers off and telescope the covers. Raise them up to access the adjuster at the bottom - I put a clothespin on the pushrod to hold the cover up out of the way. Back off on the adjuster enough to remove the pushrod and cover.
Here's an idea before you do all this.....have you tried a longer bolt? It could be that there are enough good threads left in the lower part of the hole to let a longer bolt tighten correctly before bottoming out.
maverickwolfe
General Topics/Tech Tips
05-28-2015 10:57 PM
Van Buren
04-21-2013 08:15 PM
Scarz
11-29-2012 10:26 AM
RidemyEVO
EVO
02-16-2011 05:11 PM
freshman
06-15-2010 05:12 PM
Quick Reply: Stripped lifter bolt 77 XLH
