Tranny problem
Tranny problem
OK here is the problem, As I am riding and come to a stop pull in the clutch It will not go in to first and it wont shift up to neutral. Now that being said if I am riding along and down shift to first then neutral is easy to find. Also when I am at a red light with the clutch in the bike still wants to move forward I have to keep the brake on.
Thanks for the help
T-ron
Thanks for the help
T-ron
RE: Tranny problem
The problem you have is called.......dragging clutch.
The clutch goes into neutral easily when the bike is rolling because all of the gears and shafts are turning together and the slightest pressure on the shift lever will drop it from 2ND into neutral.
When the bike is stopped it seems like it is stuck in gear because the clutch is dragging. Imagine the gears' dogs (ears) having constant pressure on them, keeping the gears engaged. And in reality that is exactly what is happening. That is also the reason it wants to creep ahead, even though you have the clutch lever pulled all the way in.
You either have too much slack in the clutch cable (1/8 inch at the lever is max) or you have the pressure plate wobbling and it needs to be lined up by doing an adjustment. Or, it could be a combination of both issues.
In anycase, you will want to do a full clutch adjustment according to the instructions given in your factory manual.
You do have a factory manual don't you? If not, it can be the first tool you purchase.........pg
RE: Tranny problem
Pay close attention to the 'clutch ramp adjustment' description given. You want to get this done correctly. Your clutch (on a 1978) should have the spacer tubes on the studs to set the clutch pressure plate at the correct distance in and to keep it in a single plane as well.
So, maybe all you need to do is to do the ramp adjustment. That is done before you have to remove the primary cover. Try it first and maybe save having to pull the cover. One short ride will tell you if you have it fixed.........pg
kylebryan
02-06-2015 09:48 AM
