carb opinions
carb opinions
77 sporster xl
im thinkin of getting rid of my khein carb and replacing it with an s&s ....should i get the super E or G...or what are your opinions of replacing the carb all together. Also does any one know if you can buy hyperchargers for the s&s's thatll go on my bike...and what do you think of hyperchargers....just tryin to get some ideas thanks
RE: carb opinions
i was going through this crazyness a bit ago myself.
here are a few things to consider.. which for me were brought to light by piniongear..
throttle linkage.. figure out how yours works(push, orpull, singe cable,or dual cable) that might sway you one way or the other as you may have to replace throttle linkage or fab something to make it work.
cv carbs.. require modification, fab work to mate up to the intake.. also stick out considerably far. but once onthey are apparently real good. the folks on the XL list swear by them, and tend to be quite bold about it too..
s&s.. the route i went.. simple to tune, simple to install, and a good tried and tested carb..small profile(hence shorty). but hello empty wallet. definetly go with the E over the G. some say that is even to big,and the g is way more bigger. you do have to go to a double cable throttle linkage... another cable going to your handlebars.. although i think that is also the case with the CV carbs.
mikuhni.. apparently a very nice carb.. no experience or knowledge.. hence why i cant even spell it. also $$
brad75raiders
09-06-2021 01:58 PM
