Ironhead A place to talk about Ironheads.
Confused by Engine VIN
Old 09-02-2024, 08:16 PM
AJSHOVEL's Avatar
AJSHOVEL
AJSHOVEL is offline
Received 11,069 Likes on 4,335 Posts
Originally Posted by The Doctor71
ahhhh...... I guess you're thinking "primary chain case cover" and "cam cover" ? I am NOT. I'm focused on the the engine castings..... left & right side
So I guess I should have been much more explicit and said:
  • left side ENGINE casting is from a 1000cc motor. That PRETTY MUCH rules out a '71 900cc (actually 883cc) motor.
  • cyl head bolts suggest the cyl heads are from a 1000cc motor. Further confirmation we're not looking at a '71 900 cc motor.
  • right side ENGINE casting is of unknown origin at this time
I'd edit my original post and make the changes, but not possible on this site. (I think that has to be done within an hour of posting)
To be honest, I never looked for the difference. Good catch. I'm guessing the absence of the numbers boss above the timing hole was the tip off ruling out '71.
Old 09-02-2024, 09:51 PM
rockersteve's Avatar
rockersteve
rockersteve is offline
4th Gear
I'll look for the "belly numbers" on the case (both sides). As I understand from link (below) provided by The Doctor 71, the number on each half of the case should (a) Match (but probably won't?), and (b) Start "771" if the engine is from a '71 Sportster.
https://sportsterpedia.com/doku.php/...:ih:engmech01b
Old 09-02-2024, 09:55 PM
rockersteve
4th Gear
Why does the lack of numbers boss above the timing hole rule of it being a '71? From what I am seeing from the links and info provided, the boss an subsequent VIN stamping on that side was no longer present from 1970-85.
Old 09-02-2024, 10:19 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is online now
Received 1,588 Likes on 973 Posts
Let me guess - stolen sportster, wrecked sprint, a file and a set of stamps?
The following 3 users liked this post by Joe12RK:
Architect (09-03-2024), Baird (09-03-2024), eighteight (09-03-2024)
Old 09-03-2024, 05:55 AM
Speeding Big Twin's Avatar
Speeding Big Twin
Speeding Big Twin is offline
Welcome to the forum. For 1971 model Sportsters I have photos of engine VINs in two different positions, both of which are on the R-H case, but the cases are different to each other. Some VINs are stamped where yours is but some are stamped further forward like I’ve seen for 1970 models. Because your VIN is so low, and if it began with 4A (or 3A), I may have expected it to be in the forward position although there may have been some overlap in this regard.
However, and as you discovered, 6A indicates a Model SS and not an XLCH. Also several characters in your VIN aren’t even consistent with factory stamping.
As indicated above, photos of belly numbers may help.
Eric
The following 3 users liked this post by Speeding Big Twin:
AJSHOVEL (09-05-2024), Architect (09-03-2024), rockersteve (09-03-2024)
Old 09-03-2024, 06:39 AM
The Doctor71's Avatar
The Doctor71
The Doctor71 is online now
Correct.
  • 900cc left side engine casting = 4 horizontal lines + a number boss
  • 1000cc left side engine casting = 5 horizontal lines
As I indicated earlier, "Belly Numbers" are most likely the next step to revealing more.
The following 2 users liked this post by The Doctor71:
AJSHOVEL (09-03-2024), rockersteve (09-03-2024)
Old 09-04-2024, 12:46 AM
Speeding Big Twin
Although the engine number was shifted from the left case to the R-H case as of 1970 models, a number boss remained in the casting of the left case for 1970-71. But the boss on the left case was omitted for 1972 and the number of ribs changed from four to five, as mentioned above. This may be when the left case casting number became 24534-72?
For 1970 models the engine number was usually stamped on a boss near the front pushrod tubes. Some 1971 models also had the engine number in that position but other 1971 models didn't.
Eric
AJSHOVEL (09-05-2024), Architect (09-04-2024), rockersteve (09-04-2024)
Silver 1971
02-25-2022 08:49 AM
MURPHCC1
Engine Mechanical Topics
38
02-12-2022 06:38 PM
CaffeineBuzz
12-28-2021 04:57 PM
klick79sportster
11-28-2017 09:32 PM
Lawdawg
03-27-2015 02:12 PM
Quick Reply: Confused by Engine VIN
