2014 fxdl vance fp3 advice
Old 09-08-2014 | 10:45 AM
Galaxie500fb's Avatar
Galaxie500fb
Default 2014 fxdl vance fp3 advice
I've got a 2014 fxdl low rider. 103ci, screamin Eagle hi flow aircleaner, 2 into 2 headpipes from a 2014 street Bob and I'm intending on using an old set of screamin Eagle 2 slips ons that state they are for of road use only. Not epa certified. No converter. My question is the v&h maps available don't list anything similar to my setup when it comes to exhaust. The head pipes have the cross over. Any advice as what setup I should flash? I plan on running it on the initial flash for a tankful of fuel than do an auto tune for a couple more tankfuls then flash that. My concern is the initial flash with my pieced together exhaust. Thank you in advance for any help
Old 09-25-2014 | 03:30 PM
fxrnutt's Avatar
fxrnutt
I have a 2014 FXDL with a k&n, bassani 2 -1 ...with a fp3. I used the map that listed V& H short shots w/no baffle, high flow air cleaner on the 103ci. Runs killer and much cooler. Then you can auto tune using that as the base map.
AmericanSCPO
04-19-2014 08:09 AM
Kick0514
04-15-2013 06:34 AM
Kick0514
04-15-2013 06:15 AM
jpowell490
02-19-2008 01:09 PM
Chief101
Exhaust System Topics
07-06-2007 10:37 PM
Quick Reply: 2014 fxdl vance fp3 advice
