starter jackshaft
Old 04-06-2007 | 03:59 PM
hogheadssa's Avatar
hogheadssa
Stage IV
Default starter jackshaft
HELLO, I PUT IN A DRAG SPECIALTIES STARTER ON MY 1990 FLHS SPORTGLIDE, MY PROBLEM IS IT WORKS TILL I BOLT ON THE OUTER PRIMARY COVER ??? ANYONE HAVE THIS PROBLEM.
HELP??? THANKS FOR ANY HELP
Old 04-06-2007 | 04:13 PM
sleepneagle's Avatar
sleepneagle
Default RE: starter jackshaft
sounds like it needs to be shimmed. Just like chevy starters.
Old 04-06-2007 | 06:48 PM
EVOrider's Avatar
EVOrider
Are you installing a new jackshaft along with the new starter? If so, I have seen a few aftermarket jackshafts be a little too big for the hole in the outer primary cover. It would cause just enough friction to make things not work like they should. A few weeks ago...the jackshaft assembly was too long for the hole and the jackshaft bolt head was bottoming out. It would work with the cover off, but not with the cover on....
Something to look into.....
Old 04-06-2007 | 07:13 PM
hogheadssa's Avatar
hogheadssa
Stage IV
i'm using the original jackshaft.thanks for the reply
Mike2105
05-26-2017 04:26 PM
XRAYRIDER
05-10-2012 07:48 AM
terrapin88
EVO
07-02-2010 02:19 PM
GRNBRT79
06-03-2010 09:48 AM
hogheadssa
03-30-2007 10:14 PM
Quick Reply: starter jackshaft
