Need a map for cams
Need a map for cams
I am finishing up my cam install on my 12 SG. I am ditching the PCV for a tune from The dyno difference on June 21 but I need a map to get me by until I can get it on the dyno. If anyone has a similar set up and would like to share the map with me I would really appriciate it. My set up is:
103"
Stealth air cleaner
Fullsac DX header with 4" RC slipons
Andrews 57H cams, (similar to a woods 777 im told)
Power commander 5 W/O autotune
Thanks
103"
Stealth air cleaner
Thanks
If you're ditching the PCV does that mean you're going with another tuner such as the SEPST or Power Vision? One of those may be required to do the dyno. I have the same cam, it's closer to the woods 222 than the 777. You may be able to find a map with the SE 259E or SE 251 to get you in the ball park. I have the SEPST and started with a map with the SE259, it has taken some tweaking but It's pretty close.
The tuner that I picked uses Direct link. Im happy with the set up that I have put together so im ok with locking a tune in and not being able to tweak it myself. I got it off of the lift today and fired it up with the new cams. I found a map that I downloaded from somewhere but it is for a decatted stock header. Runs like crap and has a pretty good dead spot. I will keep searching for somthing similar.
And you're happy with it???
Please say you're just screwin' with us....
I could have worded that better! I’m happy with my setup as far as parts go. I have the exhaust, A/C, and cam combination that I want. No plans to add or change anything therefore the Direct link works for me because once itsproperly tuned I cannot and should not need to change anything myself. I am just looking for a map to make it run decent until I can get it to the tuner. I will keep looking for a map for a cam similar to the 57H like the ones that mechinicalman suggested since I am yet to find a map for a 57H
