power commander 5 ?
Follow the instructions on specific mounting if applicable. It is plug and play if you read the instructions, it plugs and (if you read the simple instructions) plays. If you look on powercommander.com there is a ton of info, FAQ etc. Do not be afraid. I am not familiar with the depth of instruction and knowledge provided by FuelMoto but would think they provided all the info you need and going to powercommander.com is not necessary. I had a PCIII for 7 years and now a PCV. Easy, just take a few minutes to learn and you will be fine.
