ThunderMax
ThunderMax
Just had the ThunderMax with Auto-tune installed on my 06 Dyna Low rider and all I can say is WOW thus far, having a hard time holding on ,put on V&H staggered slip-on and a Ness Big Sucker air filter setup before I had the ThunderMax installed and needless to say there is a big difference but what’s so cool is the simplicity of the whole ThunderMax install and configuration.
I am howeverhaving some instrument issue and was wondering if anyone else was having the same, not certain if it’s just the way the Thundermax ECM works or is it something to worry about at all. First thing is turning the ignition switch on via the key, turn indicators blink 4 or 5 times and both tac and speedo kind of pegs like it took a voltage hit or something after that things seem to be the norm for a startup, but on subsequent startups without removing the key, things are a little different. When turning the bike off using the engine off/run switch, the tac sticks a 1K for a second or soand as soon as it drops the engine check lamp comes on and stays on until you re-start or turn the key off. The engine lamp normally comes on when the bikes ignition is first turned on and stays on for about 4 seconds doing self-diags, this will happen if you toggle theoff/run switch also.
So is this second engine light a problem or not, or is something not working right.
Thought I would check herebefore calling Zipper.
Thanks,
Big BrainBob
06 Dyna Low rider
Ness Big Sucker
V&H Sip-ons Staggered
ThunderMax/Auto Tune
Thanks,
Big BrainBob
06 Dyna Low rider
Ness Big Sucker
