Gas mixture question
Old 04-09-2014 | 07:37 PM
drgibson's Avatar
drgibson
6th Gear
Default Gas mixture question
We have gas station nearby now that is selling non-ethanol gas. Unfortunately it is only regular grade. Would that be any better than the premium grade with ethanol or does the octane win out over the purer mix?
Just curious.
Got an app for my iphone that tells me what stations have the non-ethanol stuff and what octane they have, kinda cool if I ever get near one of those with non-ethanol premium.
David
Old 04-09-2014 | 07:56 PM
usraptor's Avatar
usraptor
I'd run it with a little octane booster.
Old 04-09-2014 | 07:57 PM
Octain's Avatar
Octain
I think I'd be tempted to try it.
Old 04-09-2014 | 08:01 PM
RANGER73's Avatar
RANGER73
Me too, My scoot wasn't designed for ethanol.
Old 04-09-2014 | 08:20 PM
Octain's Avatar
Octain
I'd love to find some non ethanol fuel, in any grade. I routinely use Sea Foam and stabilizers in all my carbed engines.
Old 04-09-2014 | 08:27 PM
Von_Zipper's Avatar
Von_Zipper
Octane and engine is pretty much as foot and shoe.
If your engine is designed for premium fuel then that's what you want to use. Lower octane will damage your engine under certain conditions. If your engine is designed for standard there is no benefit using premium, as a matter of fact premium will burn too slow and can theoretically damage your valves.
Conclusion, use the octane your engine is designed for, ethanol or no-ethanol does not matter in this regard. And do not listen to wannabe pundits who tell "I've been doing it for months, years, lifetime and nothing bad happened".
Old 04-09-2014 | 11:10 PM
wurk_truk's Avatar
wurk_truk
What this member says is correct. Octane wins out.
Old 04-10-2014 | 02:17 AM
drgibson's Avatar
drgibson
6th Gear
Thank you everyone for the input. I sorta figured octane was more important than being non-ethanol so guess I will keep on doing what I do assuming the newer engines (mine is a 2013) are designed for the ethanol. According to this app, there are some stations who have premium non-ethanol but not as many that are regular only AND none of them are around here. Good excuse for a road trip.
David
Old 04-11-2014 | 03:57 AM
95ci springer's Avatar
95ci springer
I tried some non-ethenal in my 78 lowrider and it didn't run all that good. I tuned it to run the ethenal fuel so I think it was running way too rich with the non-ethenal fuel. When tuned right, ethanol fuel will give you more performance.
rutcutter999
06-28-2014 06:16 PM
DannyZ71
09-16-2011 11:36 PM
Topspin
12-29-2008 04:18 PM
jayhantz7
03-14-2008 10:01 PM
acedantinne
09-01-2007 02:31 PM
