fuel pak??, ** INSTALL UPDATE*** 04/03
I just ordered one for my 07 ultra.
all I see in here latley is a ton of PC prob's and questions.
not much on V&H
so , I;m wondering hows it going with the FP?
any tips tricks?
guess I'm kinda glad I didnt get a PC
!!!!!! finally installed... go to 04/03 post!!!!!!!!!!!!!!!
not much on V&H
any tips tricks?
RE: fuel pak??, your thoughts
I have an 07 FLHRS and am considering the Fuel Pak. If you are just doing exhaust & a/c from my reading the Fuel Pak seems to work quite well.
Advantage is no computer, dyno tuner needed, V&H tech support seems good, and you are not messing with theO2 sensors in an 07. If warranty work is needed, just unplug it and your stock ECMtakes over.
For the price & simplicity I think it is worth a try.
Let us know how it works out. Good Luck
I went with the Cobra FI2000 system on my '07 Heritage (at my dealer's suggestion). It is about the only system out there that retains the function of the O2 sensors. They are there to make the bike run better... why not use them? The cobra system runs great - mapping is spot on, no backfiring on decel, etc. Other mods to my bike are the SE air cleaner, and V&H big shots long. --Karl
ORIGINAL: electaRICK
not much on V&H
any tips tricks?
not much on V&H
any tips tricks?
I put one one my cousins 06 street bob, big radias pipes, kuryokin hypercharger he seems to like it alot. I on the other hand don't feel like he has the right settings but V/H says there right. The bike back fires on a down shift. Not real bad just bad enough i'm glad it's not mine.
not much on V&H
any tips tricks?
not much on V&H
any tips tricks?
well if you go to V&H web site, they have alot of info mostly for their product,, but some aftermarket companys also,
I feel if you go with what they know and have done, you should be ok!
plus Serts are on back order til end of April.
I feel if your doing slight mods, little more air in and out, fuel pack should work....
if not, I'm out 2 bills
