Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Et guys can anyone tell me the proper throttle blade adjustment on my 2007 street glide
I heard the adjustment screw Wes bad to back out on this model
Thanks
ROD
I think my flap in the throttle body is closing off all the letting no air in at idol except what goes through the iac
I was wanting to know what the correct adjustment is
From what I understand the screw is not to be adjusted....I adjusted mine to get a lower idle. I have played around with it since then.and recently i have adjusted mine down to where it shows)% at closed throttle , but immediately shows TPS value at the first touch of applied throttle.I read the TPS via TTS mastertune software... I adjusted it with engine off but ignition powered up.
If you can data log it try to get the iac to show as close to 40 steps as possible at 105*C. I don't thing adjusting the stop to lower the idle will have much of an affect as the iac will just increase the steps to maintain idle.
