A Good SERT Map for V&H Bigshot Longs & SEAC
Dealer did a Dyno baseline run free of charge and said I should save my money because a full dyno tune not needed. I have SEAC, Vance & Hines Big Shot Longs, and SERT with a Stage 1 MAP. The baseline showed that Air/Fuel mixture was right on all through the run except from 5500 to 6200 rpms. At the top end it was running slightly lean. Horsepower max was 68.89 at 5200 rpms and torque max was 81.91 at 3500 rpm. Torque stayed above 75 from 2100 to 4600 rpms. Torque was still above 70 at 5000 rpms. I think I will save the $210 for a dyno tune.
RE: A Good SERT Map for V&H Bigshot Longs & SEAC
I'm using this one... (maybe the same one your dealer used?) Just bumped up the ve tables a little bit. Haven't done a capture on it yet, but it works pretty well right off the CD.
Calibration # 78: 2007 Touring Exhaust with O2 Sensors
Configuration: 1580 SE A/C & Race Exhaust
File Name: 159PZ003-A0.MT6
07FLSTC
Kuryakyn AC
V&H Big shots long
TJRKC
03-08-2008 06:35 AM
Ripsnortr
02-23-2008 04:46 PM
oldfartjc
02-14-2008 09:26 PM
