Saddlebag LED/Spoilers wired as turn signals, too
If you have the HD saddlebag LED/spoilers, they can be wired (easily) for run/brake/turn signal functions. Instead of using the accessory connection for the power (which provides run/brake), use the HD run/brake/turn signal module and simply wire the red/yellow wire from your left saddlebag LED/spoilerto the violet wire on the output side of the module (for the left side LED/spoiler) and the red/yellow wire from the right side saddlebag LED/spoiler to the brown wire; and connect the black ground wires from each LED/spoiler to the black wireon the output side of the module. You will have one wire left over from the LED/spoiler wiring from each saddlebag LED/spoiler, but it is not needed.
Just as the module will convert the stock turn signal lamps into run/brake/turn signal functions, it will do the same for the saddlebag lid LED/spoilers.
