No Power to my Iron 883. Fully Charged Battery
Help! I'm getting frustrated. I have a 2013 Iron 883 that is not getting any power from the battery. Brand new battery that is fully charged. I am getting a drain on my tender light but NO power when i turn the ignition on and put the Run switch on. All fuses appear to be good also. I just shipped the bike over from the states to Germany and it worked perfect before I left. Any ideas?
does it have circuit breaker or a maxi fuse ? no power anywhere or does it have power to non switched accesories but not to anything controlled by ignition switch? try a test light or volt meter and start working out from battery . also check both side of the battery cables if you havn't already
BadYates313
07-12-2017 09:22 PM
gulatij
03-15-2012 08:35 PM
