Why do I need a larger Throttle Body?
Old guy new to bike EFI. Just when I think I have a pretty good grasp of basic performance, I keep stumbling across references to HPI 51 and HPI 55 throttle bodies I presume. Jeez! What do you have to build that needs to breath through a 55mm TB?
BTW, what are the spec's on the stock HD TB anyway? Size? CFM? Injector rates?
Also, I thought that by moving up to EFI I would get out of the Mikuni big carb rat race. Yeah. Right. Just a migration up to fancy electronic carbs now I guess.
Uh no. I know when you build a Sporty, the CV40 turn into a Mikuni 45 after about 100hp.
Up on the table is a 2007 Dyna TC96. What size is stock and at what point does that need to grow? Worked heads with larger valves over a big cam? Is stock sized pretty good and how far can it go? When to go larger bore and/or larger injectors? X hp or Y displacement?
What you get with EFI is the ability to fine tune the fuelling to a much closer degree than is possible with a carb. More engine needs more air as well as fuel, hence bigger throttle bodies! If you are actually making mods to your bike are you doing so with the help of a local tuning shop? Id so they should be able to advise on the best combination of parts, including throttle, to get the best from your build.
94 ultra
Engine Mechanical Topics
09-03-2021 06:30 PM
