Can anyone help me with engine check light
Hi guys, I just installed a power commander III on my 2006 ultra. I also put on a K&N air filter upgrade RK-3910 kit and SE slip on mufflers. The guy I bought the power commander told me he would set it up according to my add on's. I take the bike out tonight for the first time and everything seems to be fine. I start gettin on her and the engine check light comes on and when I let off on her the light goes out. I can run her at certain rpms and everything is fine. It seems like only when I step on it that the light comes on then a little bit later it goes out. I cant put my finger on it. It was fairly cold out if that has anything to do with it. The oil pressure was around 30 psi and the oil temp was near 190 degrees. If anyone knows what to do please let me know thanks in advance for all who respond.
RE: Can anyone help me with engine check light
Start here:
https://www.hdforums.com/m_43975/tm.htm
This will give you the procedure for retrieving the historical codes. Once you have them, post them here and I am sure someone will help you out.
ORIGINAL: HDSTORMDANCER
No I didnt set the throttle position. I wasnt aware of that. Can you tell me how this is done.
