Tuner needed?
Tuner needed?
Currently got a 08 FXDB with DK air cleaner, cycle shack slip ons, and some XIED's. It seems to run good/fine. I'm looking to install a performance cam myself. (S&S 583 ez start) Would the XIED's be enough for this kind of upgrade? Not looking to get sold the thundermax or any other auto tuner. ($$$) What are my options on budget???
THanks!
THanks!
Received 4,230 Likes
THanks!
THanks!
https://www.hdforums.com/forum/ignit...uning-etc.html
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
THanks!
THanks!
The xIED's will not work with your stage II build. When you install cams you change the way the bike breaths. The ECM has a preset calibration for your stock cams. This calibration must be reset to conform to your new cams. The main reset is VE's or Volumetric Efficiency. This calculates how much fuel is to be mixed with the % of incoming air. Second is your timing. A device that fools the bike just will not give you the added performance you are looking for.
No need for an auto-tune product. There really isn't such an animal anyway. All tuning products still need the owner and a computer in some way to save data and overwrite a calibration.
However, you will need a flash tuner of some brand to assist you. Without doing it properly you run the risk of damaging your motor.
Easy answer? NO. XIEDs struggle on a stock bike, and for reasons staed by Wiz, will not even come close.
You need a tuner, plain and simple. If the budget doe not allow this? You simply cannot do cams. Think of it this way... would you do cams on a 70s car or an older bike without altering timing and installing bigger jets? Same difference only way more sophisticated.
I, myself, recommend purchasing a TTS, and learn how to use it. Other wise, find a dyno tuning shop (not a dealer) and whatever device they like to use, be it TTS, PV or SEPST... buy that product and let them tune the bike.
A TTS costs around $450. A full on tune (with tuner) is about a grand. NOTHING is easy anymore with the EFI stuff and its either pay or don't play.
Your option budget device would be to buy a PC3 and have it tuned. Totally cheapest way to go would be to buy the PC3 and hope Dynojet has a base map that matches. Install the base map and ride and see. This will work on that 2008 bike. Expect gas mileage to plummet, tho. The FuelMoto micro tuner is a PC3 variant. Also, there should be plenty of used PC3s laying around. I bought a never installed, used, PC5 for the shop. That was $230 to my door.
Do NOT purchase a used 'flash' tuner.. TTS, PV or Sepst. These units marry themselves to a bike and thats that. PC3 and 5, OTOH, do NOT marry and can go from bike to bike.
Flash tuners keep the O2 sensors and there is nothing left on the bike when done. PCs are 'add-ons' and stay on the bike and add a layer into how reliable things are... simply because it is another thing to break at some point. PCs can be disconnected along the side of the road and a bike can be possibly be ridden a short distance to somewhere for help.
PCs do NOT use O2 sensors.
THanks!
THanks!
bpav16
03-07-2010 08:44 AM
