Security System Recovery on Salvage Bike.
2007 FXDL Low Rider TC96 - Salvage
Must have the optional Smart Security alarm system because when the battery is connected and the key turned on it goes into alarm mode. Seller says it will need a fob programmed by the dealer. Sure would like to hear it at turn over and even run before going any further on this salvage piece.
> They just need the VIN and a technician can 'associate' the $44.95 replacement fob? (per the Electrical Diagnostic Service Manual)
> Does the bike need to be there too?
* The factory default code setting is simply "12345". If not previously changed, this code entered through the turn signals turns the alarm off without the fob.
* The PN is 68922-07 for the module and 68926-07 for the fob. The module simply replaces the turn signal module.
